Thread: SWB front oil cooler
    I am building a 68 car with a 2.5SS engine. I am thinking to install a front oil cooler.
    Which system should I use ? Somebody told be the later 74 oil cooler system is the easiest to fit.
    Which are the best to fit?
    Bruno
    I did this on my 67, used 69-71 oil thermostat lines in engine bay, custom made lines in wheel well to 74 lines along rocker panel, piece of old trombone line to improve the oil line curvature at the front rocker to fender curve, and then 911 Carrera front cooler and louvered plate in normal position in rt. front fender.
    Aug 2010
    Colorado
    I used Elephant Racing passenger side front oil cooler, lines and thermostat on my 67.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
