Results 1 to 10 of 15
Thread: Unfortunate end to a great drive in Napa Valley
    Aug 2009
    SF Bay Area
    More details to follow
    Aug 2009
    SF Bay Area
    My wife and I were just cruising along when the car started to hesitate just a bit, I pushed the accelerator pedal down and it stuck wide open. I shut off the ignition and coasted over to the side of the road. I tried to free up the frozen carb but couldn't so called the tow truck. Got home and removed the LH carb and found part of the auxillary venturi stuck in the butterfly which jammed the carb wide open. The other part of the venturi is nowhere to be found. SH*T!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. I guess the thing broke from vibration over many years. These are Dellorto carbs and have been the sweetest running carbs I have ever used on a 356/912 engine, until now.
    Jim
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    Ooopsss... not sure I want to see inside that engine. Sorry Jim!
    Hope its behind the valve somewhere.
    Jan 2007
    Phoenix, AZ
    I once melted a Dellorto venturi into the head during a small carb fire(car was still running!).
    Jan 2017
    NY/VT
    I hope David is right. Good luck.
    Tom
    Apr 2008
    Virginia's Blue Ridge
    Well that sucks! Glad you and the Mrs are safe.
    Aug 2009
    SF Bay Area
    Found the wayward part. Bullet dodged.
    Jim
    Does the old adage of "rather be lucky than good" apply here? Of course being lucky and good is even better!!!
    Early S Registry #235
    rgruppe #111
    Senior Member larwik's Avatar
    Dec 2003
    Los Angeles, Ca
    I think Jim is both "lucky and good"
    Congratulations, Jim...I use Dellorto/36's on my -65SC...and I absolutely love them too (stored the original Solexes)...I saw your post and I was thinking...Oh'man, do I need to worry about this now?...How common is this?...I have never even heard of the venturi braking off....but then again I have never won the lottery either....Thanks.../ Lars...
    Lars Wikblad...
    Early 911 "S" Registry # 527
    "R" Gruppe # 314
