Results 1 to 2 of 2
Thread: Targa Struts/Brace plans
    Sorry if this is a repeat question, I searched but didn’t find many threads on this.
    I’m currently stripping a ‘68 Targa that is going to need floors and gas tank tray replaced at a minimum. What sort of struts or supports have you used in the past to support the car while undergoing media blasting and metal work? My initial thoughts were to run struts from the top door hinge to threaded seat belt anchors. Will this be sufficient? Would you run the struts diagonally front to back? Struts from both top and bottom hinges?
    Thank you!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    For such extensive repairs a chassis jig would be more appropriate.
