Results 1 to 10 of 17
Thread: '69t front pull cooler fitting leak
    Oil leak from this fitting. Is this an easy fix? Any leads on where to find this section of line and fitting?
    Glen
    99 Boxster - Spec Box #83
    2014 Cayenne GTS - grocery getter and tow rig
    72T - Gemini Blue (work in progress)
    The tricky part may be getting the lines off, but once that is done those are just factory lines, or look up Brad Davis on this site, send him the lines and he'll make new ones. And do both.
    These are the stock '69S cooler hose part numbers.
    PET '65-'69 911, Fig 1-04-05, #15 901.107.364.00 Oil pipe, oil thermostat - oil cooler Qty: 1
    Sierra Madre, $150.55
    Einmalig, $71.26
    PET '65-'69 911, Fig 1-04-05, #16 901.107.361.10 Breather hose, oil cooler Qty: 1
    Stoddard, $186.11
    Sierra Madre, $165.60
    Einmalig, $71.24
    But your cooler appears to be 78-83:
    PET '78-'83 911, Fig 1-04-05, #11 930.207.046.01 Return pipe Qty: 1
    PET '78-'83 911, Fig 1-04-05, #12 930.207.045.01 Intake tube, -80 Qty: 1
    Banned
    Nov 2004
    Scottsdale, AZ
    Stock S hoses won't work. By my observation that's an '84 Euro cooler and later lines on a long hood. (With no visible means of support from an upper bracket for the cooler. At least that I can see.)
    Buy stock 76-89 front hoses from just about anywhere. Super inexpensive.
    Thanks guys... super helpful.
    Glen
    Nov 2003
    Santa Monica CA
    Is that oil cooler connected to anything?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Thanks for the help guys. Turned out to be a relatively easy (albeit messy) project. Yes, there is a strong bracket on the bottom with two rubber bushings. At some point, I'll fab a second bracket for the mount on the top/front (but it's relatively sturdy as is)
    Quick question: after assembly, I started the car on the lift and tried to bring it up to temp for the oil to run to the cooler... is there a thermostat somewhere that a can jump to test everything out without having to actually get the oil temp high enough to trigger the thermostat?
    Glen
    Not that I know off Glen....
    I believe the standard thermostats opens at about 190, just a few ticks above running temp, it not too hard to get it there... When both hard lines are hot it's open....
    Hope this helps,
    cm
    98 Chevy S-10 Utility
    15 GTI Commuter
    As per Frank's observation. It looks like the top support tab on the cooler is not secured to the back of the headlight bucket as it should be. the resulting movement and vibration might be the source of your fitting failure/leak. Generic lines, but not so cheap any more.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Any tips (or photos) for fabbing a bracket for that location behind the headlight bucket? Also, do you recommend high temp thread sealant for the fitting connections?
    Glen
