Thread: Long Hex Nut for Pierburg Mechanical Pump - Need Dimensions Please
    Jan 2007
    Phoenix, AZ
    I need to make a couple of the long hex nuts for the lower stud mount on a Pierburg mechanical pump. Could someone measure the length and width for me? I'm assuming its 13mm across the flats like the upper nut but want to be sure and know the length. Thank you in advance!
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    I need one too. Following.
    In this thread it is suggested that the nut is about 5cm long.
    http://www.early911sregistry.org/for.../t-124922.html
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    Oct 2010
    Southern Ca.
    I don't know the length but I know it is 12mm across the flats as the top nut should be .
    Jan 2007
    Phoenix, AZ
    The thread from above is interesting. I've only seen two presumed originals and they were both closed at the end, thus not a coupler as referenced in that thread. Has anyone else noticed that on a known original?
    Oct 2010
    Southern Ca.
    Yes , the originals I have seen were closed on the end.
