Thread: 1968 S VIN details
    1968 S VIN details
    Hi,
    I am looking at a 1968 S and wonder about the correct VIN 11800XXX details on the car.
    The aluminum plate at the front latch panel has '911S' and the VIN without the 'S' stamped into it, correct?
    The VIN on top of the tank inside the trunk is without a 'S'?
    The a-post tag has the VIN as well without a 'S', correct?
    What about the number on the knee pad panel? I think up to model year 1967 you will find there the VIN, if it is a S then with a 'S' at the end.
    From 1968 on I am not sure. Is it the VIN (with or without the 'S'?) or the production number. If it is the production number, how can I check if it is the matching one? A Kardex won't show it, doesn't it?
    Michael
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    I was about to post a very similar request for a car I am working on stateside. It would be helpful for me if someone would post pictures of unaltered vin stamps for both the radio area and the under hood area. Specifically for 1968 911 S
    Here's the stamp and tag from my 1968 911S Soft Window Targa
    Oct 2008
    Burford, ON, Canada
    The model is stamped into the Typ box and coded into the VIN (Fahrgestell Nr.) thus the extra S used in 1967 is not required. The production # on the dash frame (knee panel) is still the VIN in 1968, so is coded with the model type.
