Results 1 to 10 of 12
Thread: WTB: 1972 Heat Exchangers
    Dec 2013
    Connecticut/Florida
    Wanted to buy - set of 1972 Heat exchangers..
    1971 911S Coupe - Gemini Blue
    Dec 2011
    Palm Coast, FL.
    If you want original and correct for 72 MFI http://www.early911sregistry.org/for...eat-exchangers
    ESR # 2300
    Bob's pictured exchangers are late 73 or current replacement. 72 and early 73's intake pre-heat path didn't use the tube on the pre-heat exchanger. The intake was on the side with a coarse screen. Those are long gone and if you wan one you will need to fabricate it. Gordon
    Here is the unavailable 72-early 73 heat exchanger. From 72 service info.
    Dec 2013
    Connecticut/Florida
    I found this one that I think is correct 552F1628-CA54-45E2-993F-8DD3D1E409F3.jpeg
    That's it.
    Nov 2015
    I could use a set too
    www.tcspeed.com
    Nov 2015
    Quote Originally Posted by Simonjjb View Post
    would this be considered the "left" as in drivers side?
    www.tcspeed.com
    Nov 2015
    would the MFI "right" side be the same for all models? or would the MFI "right" side be a different piece?
    www.tcspeed.com
    All right sides should be the same.
