Thread: Heater Valve - 1967 911 - Original color?
    Apr 2013
    Northern California
    Does anyone know the technical color specs (red) for the original heater valves? Mine are in great shape, just need to paint them.
    Thank,
    Don
    Don,
    If you're talking what comes off the heat exchanger I think this (of many) threads will help:
    http://www.early911sregistry.org/for...pper-Red-Paint
    Search is your friend...
    cm
    Apr 2013
    Northern California
    Yes, your information/link helped. I'm going to try the Wurth Rust Stop and see how that looks. I think I can find it here in Sacramento, CA.
    don
    Aug 2013
    Westlake Village, Ca.
    I use red oxide primer and then put a semi-gloss clear over it and it looks pretty close to original.
    Scott
    303581
