Results 1 to 10 of 10
Thread: Fuel tank filter screen replacement
    Sep 2009
    UK
    Is there an alternative to buying the hugely expensive fuel tank fitting. https://www.pelicanparts.com/More_In...01-023-06-M100 The mesh screen has pulled away from my original fitting.
    Any ideas or is another wallet bashing imminent.
    EDIT: looks like i can just use a VW screen on my original fitting. Google was my friend.
    Dave
    Not sure how you can attach the VW one, the original screen is crimped on, I think the VW one is captured by the flange of the fitting?
    Sep 2009
    UK
    For 10 bucks Ed, i think i will give it a go with twisting some mig wire to try to hold it. Nothing to lose.
    You can also post for a used one. I have spares if you can't locate...Use new seal ring
    John Schiavone
    Connecticut
    356 Cab, 66 911, 914-6, 911-50, 981 Cayman
    Sep 2009
    UK
    Thanks John. Ordered new seal rings from Porsche. This is a part i would want new on my fuel system.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Quote Originally Posted by stretch View Post
    Nothing to lose.
    Except the screen coming loose in your tank, then you have no filtering and it would be a bit of a pain to try and get out. But you will only know it came loose when your fuel system starts to act up because of debris which will take a bunch of diagnoses to figure out. Geez, what are these cars worth? Pay the $100 and do it right the first time. Sorry, don't like hack jobs.
    Just my 2 cents.
    Mark..
    Aug 2011
    Virginia Beach Va
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Sep 2009
    UK
    Mark, i think i might be a little bit smarter than that. I asked if buying new was the only solution, not if i should splash the cash. Maybe i should throw everything out and buy new.
    Dec 2010
    Southold, NY
    Sometimes, when considering the labor involved in replacement, that is the wisest choice.
    Sep 2009
    UK
    Couldn't agree more. Just about to throw my CDI harness in the trash.
