Results 1 to 8 of 8
Thread: FS: Rebuilt pedal cluster (68-73)
    For sale a rebuilt pedal cluster.
    This is for a 68 to 73 911 or 68 or 69 912. (w/ bracket for brake switch)
    This one was very nice to begin with. Sanded, scraped and wire wheeled it to start. Primed everything else and put a top coat of Rust-oleum Semi-gloss black.
    All new springs, bronze bushings, and rubber stops. Had to source a new clutch shaft from Porsche. It is different than the original but will perform the same. These are getting harder and harder to rebuild but now it is perfect. Works very smooth and really one of the nicest one I have done (I have done about a dozen of these).
    One odd thing is it has a hole in the bottom bracket near the front. Never seen this before. Don't know if someone did this on their own at it came that way. It won't really came into play, just haven't seen it before.
    You will have to use your brake rod, throttle linkage and brake switch. All washers, cotter pins and bushings included.
    $275 shipped in the US. Others, we can discuss. If you want to send me your old one I will give you $50 off (you pay shipping) if it isn't too bad, you decide.
    Thanks, Dean
    Senior Member DavidRees's Avatar
    Dec 2011
    Sarasota,FL
    Nice work Dean! Is it possible to have the bracket media blasted & black powder coated & if so what are the total costs?
    Don't know what you are really asking?
    Not sure if you are asking me to do that to this cluster or just a general question.
    I don't usually powder coat, so I don't know what that costs is.
    Not convinced it is really necessary on these parts.
    Sorry, Dean
    time for a bump
    How about $250?
    Dean
    Weekend bump.
    How about $225?
    Dean
    Need this gone bump.
    Dean
    this is sold
