Dirk,
If you get the transmission stuck in reverse again (I've had this happen to mine a couple of times due to extenuating circumstances), you can kind-of-easily get it out of reverse by removing the backup light switch and giving the pin for the reverse lights a tap which will knock it out of reverse.
Cheers,
Keith
