Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Which original antenna for 911 from 69-73?
  1. #21
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    Quote Originally Posted by LiveFromNY View Post
    Lots of info out there on this. In general, the Hirschmann AUTA 4900 LS 18 antenna is considered most correct for 70-73 cars. It's identical up top to the factory installed antennas with only slight differences under the fender. It was also the antenna commonly installed by dealers back in the day.
    For 69 and earlier cars, it get murkier. I continue to believe that the Bosch blue tips are most correct for 1969 cars as I have three original cars that were delivered with that antenna. I've also seen other antennas on 69 cars claimed as factory installed so there are likely multiple correct antennas for 69 and earlier cars.
    Have you seen if the blue-tip antennas, on your cars, have any Bosch part number(s)? Bosch has very good historical archives, but its easier to search if you have the Bosch part number.
    Best Nick
  2. #22
    Feb 2013
    Europe
    Based on the above we can assume that for a late model 1965 and a model 1966, a Bosch V 98 NP (AT766/12n) was sometimes used.
  3. #23
    Aug 2011
    Eugene, OR
    I have more than one original 73 car with the previously referenced chrome antenna. I have never seen what I believe to be an original 73 with a black antenna. I currently have two 74 cars optioned with black trim that have a black antenna. In my opinion, the switch was made sometime in 73 but only for 74 cars so optioned.
    Quote Originally Posted by Nicklasliljegren View Post
    I'm not sure exakt when they changed to black chromating.
    My friend has a very late '73.5 T targa (6/73) that has a black Hirschmann. Don't know if it is original or not. I'll take a closer look at it next time I see the car.
    - Arne
  4. #24
    May 2012
    UK
    ...I believe black.mast is later. This one certainly is later it is however Hirschmann marked on fittings and with a Porsche parts traingle and part number sticker. Has the later two prong screw tool for use on the top and a key to release.
    My car 73 car has Hirschmann electric on other side however
    Steve
  5. #25
    Feb 2013
    Europe
    ˆˆˆ This is the famous Hirschmann 4000 M 801, with part number 911.645.301.04.
    This one is listed in the 1973/74 Hirschmann Katalog.
  6. #26
    May 2012
    UK
    Hi Adore911...that is correct apologies for poor blurred pic of part number but that is the number on the sticker along with the P triangle which rather suggests it was the one Porsche chose to fit for the earlier impact bumper cars. I picked it up somewhere but shan't use it on my 73 model car as too late part and car drilled the on other wing ( fender). Maybe the very last of the longhoods -- I know of some cars that were registered after the longhood era and possibly as local fit.
    A P part sticker is a neat touch bringing certainty context of the discussion
  7. #27
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    The black chrome antenna with the black nut, which needs the two prong screw tool, was introduced in summer 72, maybe to match black horn grills, black lense trim, ..... but I donĀ“t know exactly when.
    It s prooven by several pictures of factory pick ups and fairs. For example RS book page 123.
    Starting April 73 both types of manual antennas had been mounted to reduce stock of the early ones.
    And it is not AUTA 4000 M481. One can see clearly by comparing the angle of the cable connection.
