Thread: What oil lines do I need
    Sep 2012
    Philadelphia, PA
    I'm putting in a fender oil cooler in my 1972 911; I have the oil cooler already; which lines do I need for the complete system...I'm looking for hard lines, either unfinned or finned; again, this is for a 1972, which I know is different.
    Thanks in advance
    Serge
    Early S Registry #2457
    Jan 2011
    DFW TX
    I think Elephant has the best thought out solution.
    do you have the thermostat already ?
    Would 2nd the vote for Elephant’s solution, I am installing their kit for 71 right fender cooler.
    The only issue I have run across is the frame ( it’s a Porsche part # actually for later 80’s 911)
    The frame allows the cooler and stone guard to mount. Connections at inside top of headlight bucket, side wall just behind the battery box and another below .
    The top of headlight is pretty starlight forward but the other 2 are tricky.
    I can post my Solution if interested
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Sep 2012
    Philadelphia, PA
    Thank you, but this is an old thread. I ended up with the Elephant finned lines last year
    Serge
