Thread: Steel Window Regulator Repair Pin for 1965 911 weird size ?
    Feb 2013
    bordeaux
    Hi ,
    On my 65 911 ( vin 302027 ) i have a steel Window Regulator pin who is broken .
    On Stoddart for example , i find one with almost the same size ( 23mm ) only one think don't match :
    it will have to be 10 mm
    thanks for your help
    vincent
    Contact Sara at PartsKlassik, she'll have the size you need
    https://www.partsklassik.com/
    John Schiavone
    Connecticut
    Aug 2009
    SF Bay Area
    Don't worry. There are really only 2 sizes. Short and long. You can actually use either one in a SWB regulator. It will fit. Your regulator is the same a all SWB ones. It is the same as a 356, too.
    Jim
