Results 1 to 9 of 9
Thread: Hex size gas tank drain plug '66 (the large plug)
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    Does anyone know the hex size for the drain plug in the gas tank of a '66? The larger of the two, on driver's side with tank installed rather than the proper center drain plug. I didn't tighten enough before re-installing tank. Now it leaks gas. A tight spot. Need to know the size before attacking my Allen wrenches with the grinder.
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
    Dec 2010
    Southold, NY
    Attacking the Allen wrenches with a grinder is not the best idea when a suitable key is easily made by welding a nut and bolt together.
    Nov 2009
    DC/Montana
    Good point. Any idea of the size?
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '76 Alfa Spider
    What tank do you have in the car?
    Nov 2009
    DC/Montana
    I believe it's the stock tank from '65. Looks like this one. http://www.stoddard.com/90120102306.html
    No large (sparkplug wrench size) drain in the bottom. It has three holes. Drain in center. Hole with fuel strainer to fuel line. And one with a plug that I think is the same size as the fuel strainer. This plug is the one that's leaking.
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '76 Alfa Spider
    I asked because I thought you were describing a 73 and later tank. There are three holes in the lower rear of your tank, drivers side is the feed line to the pump, and has the filter sock. That one takes a 27 mm open end wrench, or a 32 mm if you have the new replacement strainer. The one on the passenger side would also take a filter IF you had a gas heater. From memory that hex size is 10 mm. That should be accessible enough for a right angle allen head wrench.
    Nov 2009
    DC/Montana
    Thank you. I'll give it another try with a 10 mm.
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '76 Alfa Spider
    Plug is DIN 908 22 x 1,5 takes a 10 mm allen
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Try the wobble head Allen.........AKA ball end wrench
