Results 1 to 8 of 8
Thread: 1970 door handle trigger piece
    The Netherlands
    Hi,
    Probably not the easiest part to find. This is the part of the 1970 only outer door handle, with the large block on the bottom what is different to the 71/72 handles. Anyone?
    Kind regards,
    Cees
    I will check the bottom of my boxes Cees as I have pulled several of these apart over the years and not reassembled
    Is it the one that slides into place into place ina groove can't quite tell from the pic
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    The Netherlands
    70 door handle part
    Thanks Clyde,
    Yes, it has a double V shaped wedge at the top that slides into the cylinder housing. Same as the 71/72 type and after that they had the claw type version.
    Kind regards,
    Cees
    email sent but think I found the wrong one, check the pics in the email
    Clyde Boyer
    2nd email sent found what you wanted
    Clyde Boyer
    The Netherlands
    Quote Originally Posted by BOYER73S View Post
    Pics received and yes, bingo, the last one is it. Address details just sent.
    BR, Cees
    The Netherlands
    got it!
    Received the part and mounted, all good. I have used a dab of epoxy for extra security. These V shaped wedges are so thin that a little more meat will keep them in the slot.
    Thanks Clyde!
    Cees
    Pleased I could help
    Clyde Boyer
