Thread: Front trunk fuse panel hardware ?
    Guys
    I have a photo of one installled but would like to confirm if correct .
    Also if someone will provide specs , could not find these parts/ hardware in parts book.
    I know you don’t see it with the cover on......but I will know .
    For a 70S.Name:  B95862E9-957C-4677-AC15-573C0EA1C28A.jpg
    Thanks for assistance .
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I just removed the fuse panel in my 72 and the screws were exactly what is shown in your photo. Hard to imagine a difference from a 70MY, but if I think of it, I can check my 70 this evening and report back.
    mac73s thanks for post.
    Also been discussing the screw type...
    I believe it’s brass but would like to confirm with others.
    I also found that the screws to attach the black frame that holds the brake fluid reservoir is the same finish.
    This seems consistent with the nuts that are on all the body ground studs in various locations .
    Was surprised to find that Brass is the 5th most conductive material after Silver,Copper,Gold,aluminum then Brass.....
    Followed by Zinc, Nickel, with Steel and Stainless Steel 11th .
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Larry M came thru with part number for these screws , although I could not find in my parts book.
    The part #900 143 029 02 M4.2x16mm pan Head sheet metal screw.
    They are yellow zinc plated .
    Stoddards has them so ordered this morning.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2006
    CT
    Not Brass?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Correct not brass as I thought was possible...just yellow Cadd.
    Tom B did not think brass either.
    Always learning.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
