Results 1 to 7 of 7
Thread: Rear Quarter Window Rubber recommended vendor
    Apr 2011
    N.Calif., south of SF
    About to replace left and right rear quarter window rubber seals (the one that surrounds the window frame, not the one between the glass and the frame) and looking for recommendations of good fitting seller of this seal.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Porsche . . .ONLY. Rubber seals that are anything other than genuine are a FIGHT to get on.
    Apr 2011
    Thanks appreciate it
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    +1 for Porsche - I would look at www.Sunsetporscheparts.com, they usually are the most competitive price-wise
    The one between the glass and frame isn't so bad.
    Early S Registry #235
    rgruppe #111
    May 2006
    CT
    I orderd all the rubber for my ‘70E project from IME. I found that most of it worked well with the exception of the rear quarter window seals (glass to frames and frames to body) as well as the front and rear windshields. For those I used OEM Porsche seals.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Apr 2011
    Thanks, appreciate the info. Ordered OEM Porsche ones.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
