Thread: Making Plug Wires
    Making Plug Wires
    I am thinking of possibly making a set of plug wires for my 1973 911S. What wire would you recommend I use?
    Thanks!
    73 911S Targa
    Depends on the ignition but this too is a much debated topic. Usually, spiral wound "glass" for MSD and solid core for CDI.
    While making wires isn't hard I usually "take the path of least resistance" (pun intended) and go to one of our fine vendors.
    Kurt Donohoe @Partsklassik has done enough research into wire type and resistance to have earned a PhD by now. He "tunes" wires and ignitions like an Italian mechanic on a Colombo Ferrari 12 engine.
    Early S Registry #235
    rgruppe #111
    NAPA solid core. Recommended by Jerry Woods. Cheap Have made several sets, and all cars running perfectly.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Beru 7mm from kingsborne wire works
    Dec 2010
    Southold, NY
    Just because one can doesn't mean one should. Put a realistic value on your time spent sourcing components and in assembly. Better to purchase a completed set of wires.
    Quote Originally Posted by ejboyd5 View Post
    What would you recommend as a good quality and value?
    73 911S Targa
