Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: FS: 2 early running engines, 900258 & 907239
    Senior Member GT3DE's Avatar
    Nov 2012
    Arlington, Virginia
    Motivated seller!!!!!
    Make an offer, please.
    Clarke
    BadDogRacing@gmail.com
    I have 2 of these running, aluminum block, early engines. All for sale:
    900258 (1965) is a running 2.5L twin plug street hot rod. On shelf, just removed.
    907239 (1966) is a running 2.0L twin plug hi-rev race engine. Currently installed in my 1969 911T vintage racer.
    Clarke
    Early S Registry member #3172
    Current
    Race: 10 GT3 pca-GT2, (2) 78 911 pca-E 3.2L
    Street: 05 997S Launch, 75 911S Gemini Blue 3.0L, 68 912
    Past
    68 912, 68 911, 69 911T, 71 911T, 72 911T, 73 911T, 73.5 911T, 75 911S, 77 911, 82 911SC, 91 964 C4, 02 996 cab, 05 997S Launch, 06 997 C4S cab, 10 Cayenne GTS, 11 GT3RS, 11 GT3RS
    "I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." Arthur
    Nov 2012
    Arlington, Virginia
    The 2.0L race engine specs:
    Sand cast case
    All internal race preparations
    Big oil pump
    Factory crankshaft
    Cross drilled center main
    Pauter lightweight Rods
    Clevite rod brgs / coated
    Factory cylinders
    Bored 81mm
    JE pistons
    Elgin racing cams
    Factory rocker arms
    PMO manifolds
    PMO 46mm carbs
    ITG air filters
    JB racing twin plug distributor
    Bosch racing plugs
    901 stainless racing exhaust
    Racing clutch and flywheel
    Clarke
    Current
    Past
    Jul 2008
    South Florida
    Prices, please.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Feb 2012
    Netherlands, Leiden
    Nov 2012
    Arlington, Virginia
    Yes, correct
    Clarke
    Current
    Past
    Jul 2003
    Jacksonville Beach
    Ok, I will bite.
    Although I have no info on 900258
    I will pm you a totally uneducated offer from a totally unmotivated buyer.
    1962 356 S Cab gone
    1967 911S Coupe
    2008 RS60 Boxster gone
    1973.5 911T targa soft window Gone
    Runge 008 Gone
    2002 996 TT x-50 Gone
    2016 Boxster GTS pts gulf orange
    1969 912 SWT pts green
    Can I be FRANK with you ?
    Live everyday like it's your last .
    Eventually you'll be right.
    Nov 2012
    Arlington, Virginia
    Great, thanks.
    Clarke
    Current
    Past
    Banned
    Nov 2004
    Scottsdale, AZ
    Leak down numbers, oil report, and dyno sheet by any chance?
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    How much???
    300359
    Nov 2012
    Arlington, Virginia
    Nope, have none of that.
    Both engines are very fresh, little use since build. They don't leak and they don't smoke.
    Clarke
    Current
    Past
