Results 1 to 9 of 9
Thread: FS: 911R Brake support (Caliper carrier), front, 901.351.410.03
    These brackets replace:
    WET '67 911R Fig 6/1, #05 901.351.410.03 Brake support, front Qty: 2
    Which in turn replaced the stock 911 part:
    PET '68 911 Fig 6-02-00, #05 901.351.411.13 Calliper (sic) carrier Qty: 2 NLA, but last list price was $107.00
    The R part has 3.0" caliper mounting bolt spacing and requires R calipers (901.351.057.20, 901.351.058.20). The upgraded version of the bracket is lighter and has 3.5" caliper mounting bolt spacing to allow the use of '69- 911S aluminum calipers or '76- cast iron A calipers. In keeping with their sporting heritage, neither of these versions have a provision for brake backing plates (#09). Due to the various hubs, rim widths and handbuilt nature of the bodies, it may be necessary to use thin wheel spacers to provide either caliper-wheel or tire-front inner fender clearance. I can provide these parts if desired.
    Material: Aluminum, 7075-T6
    Finish: Ra 12µm (As machined)
    Anodized, Type III (Hard, clear)
    Weight, 3.0" spacing: 223.53 grams
    Weight, 3.5" spacing: 217.67 grams
    Both versions require the same rotor:
    PET '65-'69 911 Fig 6-02-05, #01) 901.351.041.16 Brake disc, vented, '68-, 20.5x282.5 Qty: 2
    New fasteners are provided:
    4, Hex bolt, M10x25, steel, 10.9 (bracket to strut)
    2, Tab washer, M10, steel (bracket to strut)
    2, Hex bolt, M12x1.5x30, steel, 12.9 (caliper to bracket)
    2, Spring washer, B12, steel (for caliper bolts)
    The kit does not include:
    PET '68 911 Fig 6-02-00, #07 901.351.481.11 Lock washer (Tabbed) Qty: 4 Qty: 2 PCNA List 2018: $14.52
    The price is $95.12 for either 3.0" R or 3.5" S-caliper carriers ($95.12 per wheel or $190.24 per axle set).
    Shipping within the US is by USPS Priority Mail ($8.45).
    Other parts for sale:
    Key Words:
    911R, brake mount, brake bracket, caliper carrier
    Aug 2010
    Colorado
    Jimmy,
    I'll take a set of 3.5 caliper carriers.
    Chris
    PM sent
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Fantastic work as usual. I would like to order a set of the 3.0" R spec carriers. Will probably never find a set of R front calipers, but nice to have
    Thanks Jimmy
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Aug 2010
    Colorado
    Jimmy,
    I just opened the box of my 3.5s. Very nice!
    Chris
    www.reSeeWorks.com
    Yellow911r
    Apr 2016
    PHOENIX ARIZONA
    Erik Black Purchase 3.5 S caliper adaptors
    Hello
    I would like to purchase a complete 3.5” spacing kit for the swb strut
    If you can please contact me and provide invoice.
    Thank you
    Erik Black
    Thdbeat@cox.net
    QUOTE=JimmyT;976983]These brackets replace:
    Anodized, Type III (Hard)
    The price is $76.78 for either 3.0" R or 3.5" S-caliper carriers is $76.78 per wheel or $153.56 per axle set.
    Shipping within the US is by USPS Priority Mail ($7.20).
    Key Words:
    911R, brake mount, brake bracket, caliper carrier[/QUOTE]
    Trick parts as usual, Mr. T.
    -Marco
    TLG Auto: Website
    I'm more interested with this for my next project dream 911R tributed
    WWW.9TREFFEN.COM
    9treffen@gmail.com
    Youngtimers aircooleds burrow in Mallorca island....
    Quote Originally Posted by Mr9146 View Post
    Thanks for the compliment. All the better to stop you with. I pity the foo' without 'em.
    Jul 2011
    Skivarp / Sweden
    Hello!
    Are the 3.5 inch carrier still available?
    Possible to send to Sweden?
    Niklas
