Results 1 to 8 of 8
Thread: 7R engine #6420085, what is it...??
    Sep 2007
    Norway
    A friend of mine has this engine, 7R case with ¤6420085¤, no type or build number. We can not find any info on this number anywhere, some kind of 914 derivation or a product from race department??
    An experienced engine builder here in Norway claims the engine number to be correct original stamping.
    Greatful for any info on this!!
    '67 911S Sunroof, Polo Red(Project disguised as a G-model)
    '67 912 Sunroof, Light Ivory(Alive and kickin')
    '67 912 SWTarga, Signal Red(Project in the making)
    X: 67 911 Coupe + 67S Targa, 912, 924, 944, 928, 356
    Feb 2012
    Edmonton
    I suspect it's a 901.38 engine (2.0L, 81kW), this would be correct for a '72 914-6
    Sep 2007
    Norway
    Thanks for your reply, yes it could be? But it is strange that it is missing the other numbers?
    914-6 engine cases were stamped back by the breather cover, not by fan housing support. Any #'s back there ?
    Sep 2007
    Norway
    I will ask my friend to check, thanks for input!
    Which engines were based on 7R case in addition to 2.7? 2.4T CIS? When did the 7R case first appear?
    My Italian 73S 11/72 had 5R-7R. But by January I believe all were 7R-7R.
    Oct 2008
    Burford, ON, Canada
    It would be very unusual for a 1972 engine to have a full 7R case. I would want photos of all of the relevant numbers on the case.
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Typically, if it doesn't have a build number and engine type it would indicate a replacement case that someone has stamped the old number to.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
