Results 1 to 10 of 13
Thread: overfilled oil change
    Aug 2010
    Colorado
    I overfilled the max mark on the dipstick by about 3/8 of an inch. What are the repercussions if I leave that much oil in the system?
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Not sure what year but it sounds like about a quart too much.
    Drain some off and avoid any of the known repercussions.
    Your wife's turkey baster with some clear hose should do it,,
    Mark
    Mar 2016
    Italy
    Oil will drain to the combustion chambers... You will see white smoke from the exhausts.
    This will not hurt anything until you have a catalytic exhaust.
    Take your car to a ride and drive it hard or drain some oil from the tank as suggested from NZVW
    Aug 2010
    Colorado
    Thanks guys!
    www.reSeeWorks.com
    Aug 2010
    Colorado
    It was almost a qt overfull. I used a transfer pump I use for filling 901 transmissions in the opposite direction. They're maybe 6 to 8 bucks at Harbour Freight. I reduced the suction side to a smaller hose so it would go further into the tank.
    www.reSeeWorks.com
    Feb 2017
    Auckland NZ
    Umm,,, How did I know that ??? ,,,
    Mark
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    I once forgot to drain the oil cooler during a change and then filled up with the same number of quarts I always use. Then went for a drive, wondering why oil pressure was so high. Figured it out pretty quick and drained the excess. But the oil pressure gauge hasn't been the same since. Registers way too high sometimes. Did I destroy the sender or the gauge?
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
    Assuming you mean the oil 'level' gauge, then yes, it's possible that the high level in the tank may have slightly bent the float arm.
    Nov 2009
    DC/Montana
    The oil pressure gauge, Ed. Have you ever heard of that?
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '76 Alfa Spider
    How does one drain the oil cooler, and why would that be necessary?
