Thread: 911 T 1971 - turn light relay change
    Junior Member
    Mar 2011
    Belgium
    Dear all,
    does someone can help in describing where this relay is located in the car ? I think I saw one in the front trunk right behind the right damper that is connecter to the hood (and the access looks like crazzy). AM i right ?
    Thank you.
    D
    Dec 2010
    Southold, NY
    Not sure if this will help with a 1971, but here's an annotated picture for a 1969:
    Jan 2011
    DFW TX
    Easier to reach from inside the car after you remove the gauges. At least on post 69 cars with push in gauges.
    Junior Member
    Mar 2011
    Belgium
    Thank you for your answer, I'll try when removing left gauge. enjoy your day.
