Thread: 2 Balsa Wood Shifter Knobs
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    Picked these beauties up from mcampuzano here on the reg. Don’t need them, other than gone!
    1) Brown one has a small crack in the coating. Does not affect the purpose and can’t be seen when installed. See pics. This is 60.00
    2) The ebony knob is perfect. 75.00
    Nov 2014
    New York
    ill take both assuming they both work with 915 transmission shafts.
    Mar 2012
    Kansas City
    These are sold, thanks!
    The cracked knob isn't mine, all my knobs have the brass insert both for strength and for perfect fitment on a 915 lever, they will never loosen with a crush sleeve or crack like the first knob.
    Also, the finish is different from mine, it's poly, I oil my knobs like fine shotgun stocks, it penetrates the wood.
    Manuel
    Quote Originally Posted by nvr2mny View Post
    Mar 2012
    Kansas City
    My apologies to Manuel. I just made the assumption that the first knob was from him as I’ve ordered so many from him over the years. Yes there is an obvious difference between the two. I will offer of the purchaser of these knobs a full refund on the first knob if he purchased it based on Manuel being the maker or thinks I misrepresented it in any way. Again, my apologies to Manuel, and the purchaser.
    Thanks nvr2mny, I appreciate your friendship and business.
    Quote Originally Posted by nvr2mny;979686<gs id="d9fe9ca1-aa26-4612-bcfc-4892f5c921e9" ginger_software_uiphraseguid="03111db7-8e5f-4f98-873d-0e9097eee851" class="GINGER_SOFTWARE_mark">
    </gs>My apologies to Manuel. I just made the assumption that the first knob was from him as I’ve ordered so many from him over the years. Yes<gs id="dcea6828-df19-44f5-a687-376af4a5842b" ginger_software_uiphraseguid="39a6a520-5b6a-4beb-aa50-2467ba3abf55" class="GINGER_SOFTWARE_mark"> there</gs> is an obvious difference between the two. I will offer of the purchaser of these knobs a full refund on the first knob if he purchased it based on Manuel being the maker or thinks I misrepresented it in any way. Again, my apologies to Manuel, and the purchaser<gs id="c247fbcf-8276-4960-ba37-21dc147fe6ae" ginger_software_uiphraseguid="4cc2072f-a464-45e5-b258-fd3a91ec2961" class="GINGER_SOFTWARE_mark">.</gs>
