Thread: Oil Pressure / Temp sensors US vs RoW
    Aug 2012
    France
    Greetings,
    are the oil temp / oil pressure sensors mounted on US cars the same as European (F° vs C° / Lb vs Bar) ? or it is just the jauge marks that differs ?
    Asking I am swapping engines (2.4T to a 2.0S) and just want to make sure I will have correct reading on dashboard.
    Cheers
    X
    O-G 26 - Early911S 2407
    If the gauge in your car shows either a scale up to 10 bar, or 140 psi that is the same thing, so look for a sender that is stamped 0-10 bar.
    Aug 2012
    France
    Cheers Ed.
