Thread: 73.5 turnsignals ?
    73.5 turnsignals ?
    Guys, want to verify proper function of turn signals.
    With lights off & ignition off .....push turn signal switch up or down for right and left turn signal.
    The front turn signals light separately ....either L or R
    Is this correct? .....thinking maybe yes as there is the emergency flasher system that should work without any power on.
    Please advise
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    If you move the turn signal stalk to either left or right with all power off the marker lights on that side should light. Common in Europe to mark car when parking at night.
    Thanks Ed, yes that’s the situation.
    Appreciate your insight as always
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
