Thread: clutch fork return spring for 901 trans
    as title says, looking for one return spring for the clutch lever on a 901 trans.
    ~J~
    air cooled only
    Quote Originally Posted by Jules Dielen View Post
    https://www.stoddard.com/90111673101.html
    Jules, a return spring for the 901 clutch fork was not used after 12 January 1967, with the introduction of the new clutch release bearing.
    Jon B.
    Vista, CA
    thank you Jon, it is for an early '67 car. I should have looked for a 'tension spring' and not a 'return spring'!
    ~J~
    air cooled only
    The spring is not used with the "live" release bearing revision. For all years of 901 transmissions.
