Results 1 to 2 of 2
Thread: Torquing Brake Calipers on My '73
    I'm reinstalling my brake calipers after having them restored, and I cannot figure out how to properly torque the lower caliper bolts on the rear. My torque wrench with a low profile socket will not fit between the caliper and the suspension arm. It's a fairly thin wrench as far as torque wrenches go, and my socket is only 1" deep - how have others managed this?
    For now I have torqued the top bolt to 75 ft-lb and done the bottom as tight as I could with my hand wrench (75 ft-lb is about as hard as I can pull on a wrench that short anyway). Good enough to drive to my new house 1000' away, but not a permanent solution.
    Any ideas?
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    https://www.google.com/search?source...oMjfaXcRtl3-M:
    Never did this chore, just a suggestion!
