Results 1 to 2 of 2
Thread: Engine oil thermostat questions
    Aug 2010
    Colorado
    I've spent the last couple hours reading threads looking for a clear answer. I'm still not sure.
    My understanding is the thermostat starts to open around 190 degrees. At what temp should it open all the way? As it is at the top of the engine can I pull it to test it without making a mess?
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Oct 2010
    Southern Ca.
    Yes , you can pull it without making a mess , but have a container to catch the oil that will be in the thermostat . At 195 to 200 it should be generally open . Some open at 160 and some never open , so you'll quickly see if yours is good .
