Thread: NOS early chrome door window frame with vent window
    Still has a lotta factory wrapping, 2picsshow where chrome was cleaned, shines nicely, glass unbroken, rubber usable. $899
    paul chappell
    Still available
    paul chappell
    Junior Member
    Sep 2013
    Northern California
    Paul,
    Seeing you have other current wiindow frame offerings other than this older listing, do you know how I can mount wind wing (vents) on my '69 912? This is a track/street car that I'm making more comfortable for longer road trips and would like to add vents due to lack of air circulation at low speeds. I assume the '69 windlow frame is longer but I dont know if this is true. Do you know if a '68 or earlier window vent frame will work or any other ideas? Currently I have a '69 frame with plastic type windows.
    Thanks for your thoughts,
    Matt
    Aug 2009
    SF Bay Area
    Quote Originally Posted by dusty911fun View Post
    Paul,
    Matt
    Matt
    look for a pair of 68 door frames. They area direct bolt in. The 68 frames are the only frames made from aluminum that have opening vents
    Jim
    Still available
    paul chappell
    Still waiting for a car that needs this nice part
    paul chappell
