60 liter tank with neck set up for hood fill. I had fitted it to my '67S, but then decided to go with a 100 liter unit. I started with a solid original tank. After fabricating the neck to the correct angle for a flush hood fit the tank was etched and sealed with ethanol compatible sealant, then sealed up and bead blasted outside. Finish is satin epoxy with Wurth SKS on bottom. Tank only. You will need the cap/flange/pan kit from Sierra Madre or Pelican. PM me for detailed photos via email as this site is a pain to load multiple photos. $475 plus shipping. L1090098.jpg
