Guys
Debating which front torsion bars to go with ...remember it’s a 70S targa.
Existing were 22F 26R ...seem way stiff for a targa.
Would trade for 19F 23R ?
Interested in thoughts
Frank
Guys
Frank
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
What are your driving goals?
Peter Kane
'72 911S Targa
Don't know whether its relevant, but Porsche originally fitted Boges instead of Konis because of ride quality on Targas. Don't know about torsion bar size and what they changed by 1970. I know they revised the body reinforcement plates several times.
Most of what I have read suggest that the Boge is best for normal driving.
As well as stock torsion bars....hey it’s a targa not a coupe .
Spirited driving at best but no auto-cross and Midwest is basically flat.
My point was that the 22/26 that we’re on the car are shown to be for R, ST or RS on later 2.7 & 3.0 engines.
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
22 is way to stiff for the front, I think the original 19's are fine for the front. You can go a bit stiffer at the rear 24.5 as on the later cars or even stick with your 26 and see how they behave.
I've used Koni on the front, the adjustable gas which I believe are now discontinued. I wouldn't be afraid of the Bilstein HD at the front and sport at the rear.
Thanks for suggestions.....going to go with the 19/23 and rear sway bar.
Will see how handling goes
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
On an S you should have anti toll bars front and rear unless they have been removed
FWIW:
I have 21 mm front/26 mm rear (i.e. Turbo Torsion) bars with adjustable 19 mm sways at each end. For shocks I have Bilstein HD front and Bilstein Sport rear. I have a nice street ride and a great setup for Autocross.
Harry
Member #789
2009 MB C300
