Thread: vacuum advance hose connection for the distributor 911E sporto
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Speaking of a 73 911E Sporto: Where do I have to connect the vacuum hose that comes from the ignition distributor to?
    Pictures of piping would also be nice.
    There should be a vacuum port at the base of cyl 1 and 4 air stack, the two lines connect to a tee, then to the distributor. Don't have picture handy.
    Apr 2016
    Stuttgart, Germany
    Thanks Ed, so there shouldn´t be a difference for a sporto compared to a manual shift version.
    No difference that I can remember Dirk,,,the #4 vacuum line went over the fan housing to a point just behind the distributor, where it picked up the vacuum hose from #1, both lines connected to the straight legs of a plastic tee, the 90 degree leg of the tee sent the vacuum hose to the distributor.
