Thread: FS: 380mm VDM Ebonite Steering Wheel - 914
    Senior Member greggearhead's Avatar
    Colorado Springs, CO
    This is the popular wheel to rewrap and make a thick rim RSR style sport steering wheel. Has a weird cloth cover on it now.
    Part number 914.347.805.11 Date stamped 72
    $250
    Jul 2011
    Chicago Area
    This is not the ideal wheel for a thick grip RSR wheel, it has the recessed nut area on the top and if you pull the back plastic housing off you will see it needs two recessed holes drilled to accommodate the 911 cancel ring.
    Mike Fitton # 2071
    2018 911S Carrera White
    Good to know - thanks for the info.
    Make offer
