Results 1 to 8 of 8
Thread: 1973 Targa Outer door moulding clips???
    Junior Member Benrenn's Avatar
    Jan 2017
    Houston, TX
    The door / window seal moulding on my 1973 Targa is loose, because a number of the plastic clips holding it in place have failed or are missing altogether.
    In the parts diagram I have (see below), the clips are designated as part # 999 591 326 02 (item 10) and 999 591 326 01
    I have ordered these clips, but instead of the small plastic clips, i received larger metal ones, that will not fit in the rail. See pictures.
    I may have the part number wrong, or my window moulding may not be original to the car. Please refer to pictures below.
    Does that moulding looks correct? Does anyone know what would be the correct clips for this moulding and where to get them???
    Thanks!!!!
    Name:  Window moulding with squeegee.jpg
    Name:  window moulding plastic clip detail.jpg
    Name:  Window moulding clips.jpg
    Name:  window moulding parts.jpg
    Membership # 3518
    1973 911T Targa
    Wondering if a 3D printer could reproduce the originals?
    Peter Kane
    '72 911S Targa
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    those metal clips look like the ones used on SWB and should also work for your car... rotate 90 deg. and slide them in the slot...
    did not know that those are still avail from the factory...
    Jan 2017
    Houston, TX
    "rotate 90 deg"
    That's brilliant! They slide right in, and then a perfect fit in the door. I guess I should have thought of that myself......
    I owe you a beer!
    thanks!
    Membership # 3518
    1973 911T Targa
    the metal clips are original.
    I think they should have a collar.
    To me, that does not look like the correct molding for a 73
    Jan 2017
    Houston, TX
    The fit is acually good now. May or may not be the correct part, but I am a happy camper now!
    thanks folks!
    Name:  moulding in place.jpg
    Membership # 3518
    1973 911T Targa
    it was the angle of the shot, looks great
