Thread: Repa-Autoflug 72-73 retractable Seat Belt Set #4
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    ++++++ SOLD ++++
    Up for sale is a Repa seat belt set with Autoflug retractors, new/modern 5-bar black webbing and Repa receivers.
    The receivers are not the original hard to find, very expensive receivers, but they are something that resembles that quite well.
    While building the ST harnesses I had to replicate the small plate that is also used on the early retractable seat belts and I had a couple more than I could use.
    I also had some VW Repa rear seat belts and I have combined the two with double folded webbing and had it professionally stitched, so that it is safe to use.
    This way you can still use the original mounting hooks that are on your standard seat. (or sport seat frame mountings)
    The retractors in this set are Autoflug retractors that will work in any position mounted, they have a slotted mounting hole, so they can be mounted left or right. The B pillar guide is the later Repa that has been freshly powder coated black and comes with the plastic repa cap that goes over the bolt. The repa tongue is in great condition, it's the type that had an extra plastic guide on the back that I have gently cut away to resemble the originals. Webbing is new 5-bar webbing that is much smoother that the original, but was the only 5-bar webbing I could find at that time. The plate is also one of my new replica plates, with fresh zinc and webbing is re-stitched with correct repa stitching by a certified seatbelt stitcher. There are no labels on the belts, but you get two labels of choice (72 or 73) that you can stich on yourself with any sewing machine. (or by hand)
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Jan 2007
    Netherlands
    Some more pictures, bolt and bracket not included, just for explanation purpose
    Rgruppe #674
    Jan 2007
    Netherlands
    these are sold
    Rgruppe #674
