Results 1 to 7 of 7
Thread: '67 engine bay hard fuel line R&R PN 901.108.532.00
    Listers,
    It looks like the hard fuel line is leaking where it comes through the driver's side longitudinal into the engine bay. This is not the hard line that runs through the center tunnel. The part number is 901.108.532.00 Here's a photo from an old thread on the 912 BBS where the fuel line looks to have been replaced but not threaded back through the longitudinal.
    http://www.912bbs.org/vb/attachment....1&d=1371606855
    Does anyone know if it's possible to remove and replace the line without removing the engine? This AM I crawled under there and bent back the retaining clips and tugged a bit. It seems to be rigidly held in place by the longitudinal.
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    can`t view the pic...but if it is leaking you need to replace it anyway--cut it in pieces rip it out and try install (without droping the eng.) a new one which is available from P...
    or if you want a NOS one i know someone in austria who might have one.
    It's only held in by a grommet on the entry and exit side of the longitudinal. Pull out from the bottom.
    Thanks Ed,
    I'll give Stoddard a call tomorrow. Nothing shows up on-line except for the central tunnel fuel line.
    Moito,
    Would that someone be you?
    - Neil
    May 2013
    AUSTRIA (tu felix)
    Moito,
    Would that someone be you?[/QUOTE]
    yep ---the fuel line available from porsche is part# 90135653201 and comes in black coating
    Aug 2011
    Virginia Beach Va
    Nothing like NOS.
    How much would you want for it
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
