Results 1 to 10 of 11
Thread: '73 turn signal unit rubbers
    Dear Forum members,
    I ordered new rubbers for the '73's turn signal units, but since I don't have a reference and they came together in one bag,
    I can't tell which one is Left or Right..
    There is a difference in the moulding on the side of the horn grille, so I tried to fit them both ways but I cannot see how they should be mounted.
    Thanks in advance!
    Kind Regards,
    Johan
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    What's the difference between heroin addiction & P-Car projects? Heroin use has it's limits.
    Anybody?
    These holes need to be filled
    Apr 2011
    N.Calif., south of SF
    Hellraiser
    I believe you are talking about the "Water Drain Sleeves" 91163125902. There are not left and right versions. See #37 in parts diagram.
    Name:  Screen Shot 2018-09-04 at 4.19.07 PM.jpg
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Dear Haasman,
    I am talking about part 36, the rubber that goes around the edge of the housing and seals the lense.
    Thanks in advance!
    Kind Regards,
    Johan
    Sep 2009
    UK
    Johan,
    maybe they sent you two of the same side. They should be in there own bags if purchased from Porsche. You being unable to tell the difference suggests this might be the case.
    Dave
    Hello Dave,
    I ordered from RosePassion, so chances are they're from Stoddard or repackaged Originals.
    There is a minor difference in them (on the edge where the lens is next to the grille)
    So definitely Left and Right. I'm just not sure which is the one for the Left or Right housing.
    Thanks!
    Kind Regards,
    Johan
    The Netherlands
    seal
    This is a picture of an original left side unit with seal. The pointy side should face the lens. Hope this helps.
    Cees
    Thanks Cees!
    Will compare this evening after work!
    Kind Regards,
    Johan
    Will try tomorrow, it was too late yesterday
    Apr 2011
    Good to know.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
