Thread: 69S MFI Engine
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    69S MFI Engine
    SOLD...SOLD...SOLDI have a 69S engine 901/10 s/n 6392035 in parts for sale. Engine case is in excellent condition, crankshaft std/std. Camshafts, cam towers, chain box's all correct date codes for 69. Full set of rocker arms, pins, fasteners. Heads are all rebuilt, casting numbers 901.104.308.1R, date codes (5) 2-69 (1) 12-68. Stock S connecting rods. All chains, I.S. oil pump, chain gears,etc. Correct rebuilt MFI pump 0408 126 005, s/n 90615418. Rebuilt 69S throttle bodies & stacks and crossbar & linkage. Correct 007 distributor. Correct 69 only MFI hard fuel lines with a set of cleaned & tested injectors. Correct 69S air filter housing with cold start tubing inside. NOS Mahle 81mm piston & cylinder kit. Engine tin powder coated satin black. Sale includes a set of new Main Bearings and Rod Bearings. Very clean 69S red engine shroud with fan, housing and alternator.
    Correct MFI heater box's and almost new Dansk stock muffler. Resurfaced flywheel, no clutch. 69 only engine bay relay panel with MFI fuel filter console. Price $22,500 plus shipping & handling. Location Bend, Oregon.
    Many more photos available.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Sep 2006
    Bend, Oregon
    Price lowered to $22,500.
    Mark Jung
    MFI Werks
    R Gruppe #686
    Feb 2007
    San Diego
    Nice start to a motor
    Quote Originally Posted by VintageExcellen View Post
    And it is well presented...it is all there and condition of all of the parts is known.
    A "smart" buyer would then have Mark build the up engine...just say'in.
    registry# 1283
