Results 1 to 10 of 12
Thread: Gas tank color check '66
    Aug 2013
    Westlake Village, Ca.
    Here is the color my painter used on my '66 tank. Does it look correct? Thanks
    Scott
    303581
    Looks more dark than the original tank I pulled from my December '65 car
    John Schiavone
    Connecticut
    Looks like Grey Wurth Shutz. I think it should be smooth Grey... Good Luck.
    Oct 2010
    Southern Ca.
    If it is an early '66 the tank should be painted with no stone guard . The paint is grey , much lighter than your picture .
    Aug 2013
    Thank you all for your replies
    Scott
    303581
    Kind of a grey-tan. The headlight buckets are a grey-tan also.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 66S View Post
    this is new to me---any pics?
    never seen this but --possibly the painters did not fully spray body colour on them and the grey filler shines through.
    Ill try to get photos but I remember restoring some swb usa Hella headlight buckets and had to keep adding tan to the grey to get the color to match the original area with Hella script that I saved. I took this headlight from my mid 66 Grrman market sunroof 911 and it might show when it was "converted" to a USA 67 911L with new block script on the rear lid and wide bumper decos. I have unconverted it, hoping to finish it soon. Probably too shiny two stage Glasurit, going back to single stage Glasurit for the next one.
    May 2013
    AUSTRIA (tu felix)
    ohhh--i thought you where refering to the bucket welded onto the fender.
