Results 1 to 9 of 9
Thread: Looking for some photos of the radio cut out 69 911
    Hi guys I am trying to find some photos of he radio cut out on
    The dash as mine was made bigger over the years . Also some
    Photos of the support bracket behind as mine has been butchered.
    If some has some measurements of the radio opening that would
    also be really helpful .
    Thanks in advance
    Jonny
    Jonny, I may be able to help, i have a 68 built 69 MY that is stripped down at the moment if that is any good? I can get you some measurements and pics early next week. I am in the UK
    Simon
    Quote Originally Posted by Jonnydaz53 View Post
    Thanks in advance
    Jonny
    Unless the 69MY dash/radio cut out and support bracket differ than 70-73, I can help with photos and dimensions...but no point if indeed the 69 is different Let me know
    Hi guys im not 100% sure if there are any differences but any photos or dims would really help.
    thanks guys
    Shape of the 1969 Radio Face Plate
    is the 1969 the same shape and size of the earlier cars 1965>1968? (Actually the same as 356 openings)
    see: https://www.partsklassik.com/Porsche...frankfurt.aspx
    Is it Knob holes on either side of a radiused corner rectangle opening?
    If they are:
    Holes are 10mm and 130mm center to center, 35.5 mm from bottom of dash.
    Rectangle is 43mm high and 95 mm wide - 8mm Radius corners. Opening is 14 mm up from the bottom edge.
    And on the early cars (65>67) the right side of the radio hole is 68.5 mm in from the edge for the glove box.
    YMMV.
    Bob
    Early S Reg #370
    Quote Originally Posted by Bobs 67S View Post
    If they are:
    YMMV.
    Thanks for the reply , but you say 43 high 95mm wide ??? i think the radio is 50mm high x 180mm wide.
    thanks jonny
    Hi Jonny,
    that's sounding like a single DIN size radio opening. Referred to as 7" x 2" If I'm not mistaken Din was not adopted till about 1984.
    From Wikipedia:
    The US standard for a DIN radio is 6.83" x 2" (although the actual 180 mm width converts to something like 7-3/32" so most people use 7-1/8" to allow for clearance) and the Double DIN sized radio is a 7" x 4".
    The dimensions given prior are for a period radio. Such as the Blaupunkt Frankfort.
    Post a photo of the front your radio and that might help get you to an appropriate opening.
    Bob
    Early S Reg #370
    May 2012
    UK
    Hi image below from antique radio website ... Have loads of blaupunkt and Becker old radios in storage but haven't measured them or validated this image but maybe picture overlying measurement of several different era units helps?
    As is probaly well known DIN is German standard covering many things hence the mm measurement maybe being useful rather than imperial frictions of inches.
    HTH
    Steve
    Sorry I may not be making my self clear it’s the aperture size not the radio .
    Regards Jonny
