Thread: Tinware paint code
    Mar 2013
    Surrey, UK
    Tinware paint code
    Hi,
    I'm getting all my engine tinware, air filter and engine mounts repainted ('70 911T). The painter asked me what finish I should go for. I've read that it all gloss, including the tinware, but I've only ever seen tinware in matt / silk finish.
    Can anyone confirm the correct original finish and recommend a paint to use.
    Many thanks
    Paul
    Wurth supply an appropriate semi gloss or silk. Available in the UK when you next visit. Although some powder coat the tin ware with a silk finish.
    Paul -
    Engine mounts flat black, glossy washers. The tin gets 80% gloss black. Danke!
    - Rob
    Mar 2013
    Surrey, UK
    Many thanks
