Results 1 to 10 of 14
Thread: Clear Plastic Brake Lines
    Hi all,
    I've tried searching this forum and online and cannot seem to find anything on this subject. I have a 1970 911E and I want to replace the clear brake line tubing that runs from the brake fluid reservoir to the master cylinder.
    Porsche part # 901 355 644 00
    Has anyone replaced theirs and with what?
    Regard
    Chris
    New ones are black I believe, seems I've always cleaned them to my satisfaction.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    yes those available from porsche are black
    have this one but obviously is the other one...
    http://www.early911sregistry.org/for...158#post884158
    Check the plastic tubing section at your local friendly ACE Hdw. Of course they won't be preformed.
    Oct 2008
    Burford, ON, Canada
    The important thing is precisely which plastic; does anyone know for certain?
    Jan 2011
    DFW TX
    I don’t know about that Ed. I use the clear hardware store tubing with my vacuum and pressure bleeders and it degrades after a while from contact with brake fluid.
    Not the clear tubing, the tubing I'm thinking of is more opaque, seems like its referred to as some kind of poly----- looks the same as the factory stuff,,,,,,can't tell you more,,,,,Ace is closed right now
    Oct 2008
    Burford, ON, Canada
    All plastics are polymers, and there are a very wide variety of them. I'm thinking it is a particular variety of nylon, however there are many varieties to choose from.
    Tygon???? Guess I need to stop by Ace and see what it is I'm talking about
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    I'd take tecalan (PA12) (careful) warm forming is possiblé
