Results 1 to 7 of 7
Thread: CV joint experts?
    Aug 2013
    Westlake Village, Ca.
    CV joint experts?
    Pulled my cv joints apart to re-grease and change the boots. I am seeing some wear on the inner housing. At what point should they just be replaced? This is not going to be a race car.
    Recommendations on replacements would be helpful.
    Scott
    303581
    Scuffing and some loss of the oxide color on the housing is to be expected.
    Check the cages for lipping or cracks, and check the balls for chips, pitting, and/or surface cracks......that stuff is not good.
    Replacement? OEM Lobro from several suppliers.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Jan 2011
    DFW TX
    Doesn’t look bad to me. Mine had heavy pitting in that area after 200k miles so I replaced them.
    Oct 2010
    Southern Ca.
    You can switch the right and left axles with the CV's and the wear in the groove will be on the other side , a fresh start for the grooves , not for the balls .
    Aug 2013
    Quote Originally Posted by smedley View Post
    Thanks, I can find the Lobro's for later years but not '66???
    Scott
    303581
    LOBRO is now GKN-LOBRO
    Quick search, Parts Geek (of all things!) complete GKN-LOBRO axle assemblies, ’65-‘68, $375
    I doubt if you’ll find individual joints. If you do, the cost for four will be close enough to the whole axle assembly that the difference is NOT worth an afternoon of grease from head to toe packing and assembling the damned things.....get the new assemblies, bolt up and go!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Aug 2013
    Thanks Mark
    Scott
    303581
