Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Misfire every 5 seconds
    I have a very strange misfire - it happens exactly every 5 seconds. I posted a YouTube - search for "Bob's 911 Misfire".
    Has anyone ever experienced anything like this? I have gone through a lot of testing of ignition and some fuel system items already -
    Thanks for the help.
    73 911S Targa
    Nov 2009
    Cecil pa
    Guessing you've already done a casual test with carb cleaner, at a few locations to try to rule out vacuum issues.
    Quote Originally Posted by 62S-R-S View Post
    Have not, but will try that - thanks
    73 911S Targa
    Bob -
    Seems like a rich/lean mixture surge. Does it do it cold and hot?
    - Rob in boulder
    Banned
    Nov 2004
    Scottsdale, AZ
    What's your CO at? Idle and high speed?
    There's a reason the factory manual has that procedure in there.
    Quote Originally Posted by Robert5995 View Post
    Bob -
    - Rob in boulder
    Runs worse cold - when warmed up it it starts the strange "every 5 seconds" misfire (rpm drop)
    73 911S Targa
    great idea - just need a CO meter! will see if I can run this test
    thanks
    73 911S Targa
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Boulder Bob View Post
    Sounds WAY too lean.
    At least for now check dwell and timing.
    I love these posts...
    "Doc, please tell me why I'm coughing. Here's a 5 second video showing me coughing."
    Dec 2010
    Southold, NY
    "Misfire?" Sharp "hiccup" in smoothness of firing or short duration drop in RPM regardless of throttle position?
    Give us some history to work with, we can assume it didn't do this when new, so how long have you owned it, has it always done this since your ownership?, was there anything done just before this all started? did it just start suddenly one day? has anyone touched anything on the engine and then this symptom started right afterwards? Mechanic's rule of thumb, go to the last thing that was touched before problem occurred.
