What's the best way to remove the dash panel (the one with radio and heater knobs) without damaging the aluminum panel and its support?
Do I have first to remove the heater commands? Or just the cover frame of the heater commands?
I guess that the aluminum panel is mounted with double sided adhesive tape. Which one to use when remounting the dash panel?
Thanks for the help.
Philippe
