Thread: Best outter rocker panels?
    I know that most all the major suppliers have reworked thier dies in the past few years. Iam wondering who is making the best stamping.
    I currently have one of Porsche’s 74 and up fitted. Its a great fit, but haven done the cut and shut on the five indents before. don’t relish going thru all the labor agin. Any suggestions from those in the know is greatly appreciated.
    Regards Bill Barnich
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by wcb4 View Post
    i know that most all the major suppliers have reworked thier dies in the past few years. Iam wondering who is making the best stamping.
    I currently have one of porsche’s 74 and up fitted. Its a great fit, but haven done the cut and shut on the five indents before. Don’t relish going thru all the labor agin. Any suggestions from those in the know is greatly appreciated.
    Regards bill barnich
    91150340206 grv + 91150340106grv
    or if you need 64-+/-66
    http://www.early911sregistry.org/for...843#post956843
    Thanx for the fast response. I should have added they are for a 72 model. You verified that porsche is still the goto on the rockers.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    May 2013
    Victoria BC Canada
    I'm having metalwork done on my '71T coupe using panels from Restoration Design, the shop is also doing a '70T coupe and the owner supplied parts from Porsche. The Porsche ones seemed to be a bit less rigid than the R.D. ones, shape appeared the same.
    Here is a shot of the left installed on my car...
    Name:  left rocker.jpg
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Jones View Post
    the sheet metal RD uses for most of there parts is thicker than the ones porsche used...thats also a reason why i don`t use there panels.
    RD vs NOS Porsche
    Quote Originally Posted by WCB4 View Post
    . . . know that most all the major suppliers have reworked their dies in the past few years . . . wondering who is making the best stamping . . .
    My Take --- from 4 years ago . . .
    . . . Outer Rocker Panels --- NOS Porsche . . .
    When I first bought her, 1059 had some rust-through on her driver’s-side outer rocker --- just in front of the jack-spur . . . showed-up during the original PPI. At that time, I made a quick decision + replaced both outers --- w/ Restoration Design panels . . . and moved on. John Esposito did some fettling w/ them, when he re-finished the car, a few months after --- not the panels fault . . . and, since then . . . no issues. To look at 'em . . . no one would know . . .
    . . . ‘cept me. And I’m an idiot
    The only real/obvioustell’ that I can see to distinguish RD’s bit from Porsche’s is when the threshold ‘s removed. Faktory panels have this little ‘window’ stamped into the upper/forward flat of the pressing. John also commented that the RD bits' contours --- at the outer edge/door bottom . . .‘need some work
    Whatever the issue --- John took care of it. And I can’t tell. And like I said . . . no issues
    But Faktory is --- Faktory . . .
    . . . and so, while I can still get Real Deal Faktory panels . . . etc
    So. 20 years from now --- when the next paint job comes up . . . these’ll get cut-in
    Aase Sales . . . $970
    HtH
