I had a car brought to me in a trailer. The guy used dirty straps. This is mostly dirt and a little oil. What do I use to clean it. It's a frost like RSR finish.
Chris
Chris
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
Simple Green.
Mike Fitton # 2071
2018 911S Carrera White
If whatever you use to wash your car doesn't work, use a rag sprayed with brake cleaner on the soiled portion and follow up wiping down with vaseline.
I may be wrong, but the strap may have rubbed through the anodizing on one spot.
I'd be wary of teh brake cleaner approach without knowing exactly what surface treatment has been used. There's another organic product around called de-solv-it based on lemon oil that works a treat on my RSR anodized wheels with almost zero effort - spray - paper towel wipe - spray - paper towel wipe - light soap - rinse - dry.
I do hope that strap hasn't damaged the surface though!
Early S #2826
Garage:
'73 E (2.7RS replica) - sold
'94 968 Clubsport M030 - sold
'67 250SE Cabriolet - sold
'71 Skyline GT - sold
'69 911S - sold
'73 911T/RS
Thanks for the info guys. I hope it hasn't rubbed through the finish also.
www.reSeeWorks.com
I'd just use a mild dish soap and water. Wont harm the surface but should take the grease off easily.
I would be VERY wary of any citrus based products on anodizing...way too acidic.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
Early S #2826
Garage:
'69 911S - sold
'73 911T/RS
I would not use normal simple green on anodized aluminum. The purple stuff may be ok.
