When ignition is turned on,without depressing pedal, brake light is energized on driver's side, but not on passenger side. Both bulbs are good.Car is 73.5 T
Pedal cluster issue or something else ?
1962 356 S Cab gone
1967 911S Coupe
2008 RS60 Boxster gone
1973.5 911T targa soft window Gone
Runge 008 Gone
2002 996 TT x-50 Gone
2016 Boxster GTS pts gulf orange
1969 912 SWT pts green
Can I be FRANK with you ?
Live everyday like it's your last .
Eventually you'll be right.
Does the other brake light come on when you push the brake pedal?
No, does not light up
1962 356 S Cab gone
1967 911S Coupe
Runge 008 Gone
Looking at the wiring diagram for 73 .....shows power goes to brake light switch from fuse 8 on the 10 fuse panel direct to the brake light switch and single wire out to (yellow/black) then splits to each harness feeding the rear light assembly for each side.
If Brake switch is bad or stuck then with no pressure it’s sending power to assumable to both sides .....unless one side has a bad ground connection. The ground for rear harnesses are a post on the body right under rear fender ( single brown wire to post with bolt)
Let us know progress.
When did this start ? Any recent work on rear harnesses ? What else lights up ?
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
Ok.
Progress report.
It was a multi issue fix.
#1 Plug at rear of engine bay was not making good contact with light harness plug. Once I fixed this , both sides lit up.
#2 Off to the pedal cluster, brake light actuator arm needed a small adjustment.
Easy peazy.
Thanks to all
1962 356 S Cab gone
1967 911S Coupe
Runge 008 Gone
Maverick...
Glad issue is solved , good work
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
